M Mml665 New member Dec 22, 2022 #1 So. I fired up the MKS and I hear a hissing sound. There is a small puddle underneath the left front of car near serpentine belt area, light brownish/gold feels like oil and has a slight fuel smell.
M Mml665 New member Dec 24, 2022 #5 Macgyver said: Timing chain cover oil leak or turbo oil line leak? Click to expand... Would turbo oil line cause the hissing/air leak sound.
M Mml665 New member Dec 27, 2022 #6 Macgyver said: Any tail pipe smoke ? Click to expand... It is winter here in Michigan so I didn
M Macgyver New member Dec 27, 2022 #7 Not a great time to work on cars for sure. Hissing and an oil leak could be a bad turbo or two separate things. The oil leak should be easy to spot once you can get under it. Then maybe the hissing will found as well.
M Mml665 New member Dec 30, 2022 #8 Macgyver, could it be an exhaust leak? I apologize for my previous reply it seems when I quote someone
M Macgyver New member Dec 30, 2022 #9 It sure could. There is a valve / T near the brake booster that "Hisses "
