Ah, gotcha.TopherSho said:Nope was curious if it would only operate in fwd mode. Pure experimenting..
glock-coma said:Maybe a good way to warm up drag slicks before a run on a private/rented track.
Would it? The question is, will the car "fix" itself without the cycling of the ignition? If you can flip a switch to shut down as you roll up to do burn out(while car running), do burn out, then flip it back on, will it re-engage awd?..TopherSho said:glock-coma said:Maybe a good way to warm up drag slicks before a run on a private/rented track.
I thought about this... HARD...
It is only a 10 amp fuse.
in **THEORY** you could rig a setup for a remote fuse off a relay. And have that toggle next you your meth switch.
Issue i forsee is I am willing to bet ''enabling it'' after the power is in and the can bus has booted will probably not work and even be ''bad'' to the system.
But.. if you power cycle with it off then do your burn out. then power cycle wit it on you would be good. but it would be slow in fast lineups likes 8's or busy 1/4 tracks.
lamrith said:Would it? The question is, will the car "fix" itself without the cycling of the ignition? If you can flip a switch to shut down as you roll up to do burn out(while car running), do burn out, then flip it back on, will it re-engage awd?..TopherSho said:glock-coma said:Maybe a good way to warm up drag slicks before a run on a private/rented track.
I like your idea about a remote fuse or switch.. I wonder if there is a way to do the mod under the car? Meaning find the wires that actually control the power distribution at the trans/ptu, put your relay there and a resistor so the car thinks it is still feeding power and does not flash the error code..?
