G
geswek
Guest
This was performed on a model 2013 SHO, I can't help you with earlier models.
I've completed the project and felt I would just throw this together with a master sheet of what I bought and some photos. It was quite an undertaking and at times very frustrating. I would be prepared to sweat some and probably swear some! I have quantities listed for just about everything you need, be warned this is ONLY for the number of sockets you have. I went through a lot more LED's than that; they are fragile and more than likely your sockets are new just like mine which means putting them in is difficult and sometimes will break them.
The build thread can be found here; http://www.ecoboostperformanceforum.com/index.php?topic=670.0
You can also see my Picasa gallery with ALL my photographs along the way here; https://goo.gl/PuFvlr
If you blew the fuse for your map lights and you can't find it in the manual; it is Fuse 4 - Demand lamps battery saver relay coil.
I take no responsibility if you blow up, burn down, catch on fire, destroy, or otherwise do something utterly stupid to your car; you are using my information as a reference and at your own risk.
Supply Master List
License Plate
3710-xHP3: 3710 LED Bulb - 3 SMD LED Festoon
Quantity: 2
http://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/3710-led-bulb-3-smd-led-festoon/239/1135/
Backup Lamp
7.5 High Power 360° Xenon White 921 912 T10 LED Bulbs For Backup Reverse Lights
Quantity: 2
http://goo.gl/2FVY4c
Map Lamp and Dome/Reading Lamp
WLED-xHP5: 194 LED Bulb - 5 SMD LED Wide Angle Wedge Base
Quantity: 5
http://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-5-smd-led-wide-angle-wedge-base/206/919/
Vanity Mirrors
F30-WHP-12V: Fuse LED Bulb - 1 SMD LED Festoon
Quantity: 4
https://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/fuse-led-bulb-1-smd-led-festoon/243/1162/
Trunk Light
4410-CW9: 578 LED Bulb - 9 LED Festoon
Quantity: 1
https://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/578-led-bulb-9-led-festoon/237/1123/
Mirror Puddle Lamps
LED Puddle Lights by DAYTIMEbrightlites
Quantity: 2
http://www.daytimebrightlites.com/Puddle_Lights_NL3C.html
Completed Photographs
Rear Passenger Map Light Issue
You will more than likely be plagued with an issue where you put an LED in all (3) sockets and they don't turn off. I discovered the issue to be a lack of resistance and need for a resistor. In discussion with others on my thread, and another thread I found online--I located the parts and what needed to be done. Please read this otherwise you too will have a problem.
First off; you are short on resistance with all three LED's in the assembly; therefore you HAVE to add a resistor to one of the LED's. I chose to use the center LED as it was most easy for me to get too. Here are photo's of what I did; this does require soldering skills! You will see the part I bought at Radioshack and how I added it to the LED.
Supply Master List
License Plate
Quantity: 2
Backup Lamp
Quantity: 2
Quantity: 5
Vanity Mirrors
Quantity: 4
Trunk Light
Quantity: 1
Mirror Puddle Lamps
Quantity: 2
