Originally posted by 01SportWagon
How To: Replace cabin filter in a Ford Flex (2010)
Time: about 5 min
Parts: Motorcraft FP-68
Tools - none needed. You might need a long screwdriver or pliers to pop retaining clip on filter cover. It is just hard to get your hand in the back to lift on clip tab. But it doesn't take too much pressure.
Step one - Empty glove box
Step two - Open glove box past rubber stops by pressing in on the sides as you rotate out.
Step three - Remove damper (key hole on left hand side)
Step four - Rotate glove box full open
Step five - Locate and remove cabin filter cover
!!! - DO NOT GET ANY DEBRIS IN THE BLOWER MOTOR - !!!
Step six - Remove and replace cabin filter (pull straight out and move around under dash obstacles)
-Notice air flow goes top to bottom or 'Down' -
Step seven - Replace cabin filter cover
Step eight - Replace damper - gently pull round end out past front of dash board and reinsert in key hole
Step nine - Rotate closed and pull in sides to clear stoppers
Step ten - Put your stuff back in glove box and close
Notes: This job was so easy my 6 y/o did it for me while I took pictures. However, I noticed an air flow direction on the stock filter, but the replacement filter did not have a direction. The direction had an offset of the filter paper/pleats from the side rails. The replacement filter was centered on the side rails.
Time: about 5 min
