ZSHO said:
pmezo33 said:
ZSHO said:
I was able to finally measure it for ya.
It measure's approximately
38.5mm. Z
I hope it helps any of our prestige members out.
Thanks for confirming that. Appreciate it.
I hope you didn't pull that tie rod just for this thread though.
IMHO its my pleasure to help out the ecoboost community in any way i can.
I'm hoping the tool you ordered is deep enough to go over the end of the tie rod and hope everything goes smooth without a hitch. Z
That's some dedication right there, and i definitely do appreciate it, but your car is going to need an alignment now if that was pulled from your car. I didn't want to put you through all that trouble. I hope that was just a spare part you got a hold of.
If it was from your car... out of curiousity, what did you use to pull yours?
And I haven't ordered the tool yet. Probably will a little later today. They're all deep enough to get over the tie rod, even the smaller sizes, it's just getting them correctly on the thread. I think I should be good with that master set. Really would have preferred to rent the tools, but it is what it is.
