Installed noisemaker,restriction pipe today maked sure everything is tight and dandy,went for a spin and noticed a slight hesitation especially at wot,never happened before,with v8 tune.any loyal members could chime in greatly appreciated.
Interesting.... I never had any issues, but I did the entire hotpipe set. This is true with stock tune, v8 with DP and T-stat adjustments, or when I added the 3BAR MAP and had LMS again adjust v8 for that also.
Is the electrical connection for the TIP (Throttle-body Input Pressure) sensor tight? (the sensor that is in the side of the pipe you replaced... looks like the MAP sensor) Are the connections and clamps tight? ...especially the one on the intercooler end, which is a little tight to reach.
