Hello folks,
This build log will be for my 2013 Flex, this one is a NON-Sony setup and as such has a significantly different build strategy compared with my 2010 Sony setup I had prior.
This build thread will include the Optima battery install I did prior to starting the official build, and we'll start with that.
The factory battery terminal setup and corresponding battery does not lend itself to easy swap out
Battery out, the first unique thing I spot is what looks to be an amp meter, via this loop sensor I'll call an amp clamp.
Battery is out, fuse box is open, and I've got the intake part-way taken off for access.
Intake box is out, and these pictures were taken to remind me what the wiring loom looked like "before".
This is the factory ground point, found on the driver's side fender. This is pretty weak!
I decided since I was already this deep in the wiring to go ahead and wire in my HID kit as well. Here's the wiring to the fuse box for power (right up top on the power take-off nut), and the in-line fuse that comes with the kit pokes right out underneath the fuse box itself, just in case it needs to be accessed.
The factory wiring loom had to come apart to make this work. This was fun! The reason for this was because the factory ground wiring was too short and too bundled for me to use it properly.
Test-fitting the battery. Fits just like it did in the 2010.
continued..
continued..
