Lightbox
  • Thread starter Thread starter geswek
  • Start date Start date
G
geswek
Guest
Please look at integrating lightbox; it makes image handling in threads so much more convenient.
mm'kay thank you.
;D
There's no support or updates since 2008, the last response to the support thread was a year ago.
I currently have an image handler that resizes them automatically and recognizes images from the various image sharing sites.
What functionality are you missing?
Eh, the one thing you outta figure out is adding the box that says "this image has been resized, click to expand blah blah"--we have it on our fanatics site but that's vb--I couldn't begin to point you in right direction.
It'd be worth it; not everyone knows to click on picture to see larger version. I normally add text to mine so folks know they can do that.
Here example of little yellow bar.
Yeh, that mod is well outdated, and has a lot of problems. There is one, I use it on my forum. Will talk to the boss. Lightbox is the way forward, :D
I see you incorporated lightbox; you just need to fix the auto-expand so it doesn't butcher the threads--right now it expands a photo and opens lightbox.
ive corrected the javascript in the theme that was doing that. fortunately i knew exactly where in the js to look.
You may just need to ctrl-f5 to trigger it.
Will make the lightbox styling a bit better and add some bordering to images on page to make it clearer you can click them either tonight if i keep awake, or tuesday.
No problem.
Sorry Ive not been around to do it earlier, but running cycling forums during the tour de france is, well, chaos.. ;)
Thanks dimspace!  Adds a nice touch to the forum.  And thanks to geswek for suggesting.
geswek said:
AHHHH; your light shadow just butchered signatures.
yeh, going to remove the shadow, and then will work it so it only ads it to "in post" images on tuesday when im free.
removing it from signatures should be an interesting css task :D
Can you fix lightbox on the signatures?
I can't link an image to URL because lightboxis picking it up and erasing it.
I wanted to put a FB icon to my photography page and it's not working.
