OK so any water/meth guru's on here? I currently have the snow performance stage one kit and I will be upgrading the controller to an ecoboost controller. I will then get the steeda intake manifold spacer and tap 4 direct port injection nozzles at an angle facing the valves. All four will be tapped on the left hand side of the foil. I will be using 4 devil's own D01 nozzles coming off from a devils on 4 port splitter. Does this sound good? Any suggestions? I will be running a 50/50 boost juice mix.
My main goal is to keep cylinder temps down! So this would be the best position for this according to devils own
Here what I am thinking about getting let me know what you think
1- 4 port direct injection upgrade( 2501) $63.95
i. http://www.alcohol-injection.com/en/upgrade/205-direct-port-injection-upgrade.html
2- 4X Devils own D01 Nozzles (63ml/min) 1GPH $22.95 (each)
i. http://www.alcohol-injection.com/en/nozzles/180-outside-mount-nozzles-do1.html
3- Steeda Intake manifold spacer (I will drill and tap for 1/8 NPT threads on the left side of the foil at an angle towards the intake valves) $144.95
i. http://www.steedafusion.com/parts/steeda-fusion-intake-manifold-spacer-2.0l-13-14-555-3192
4- Snow Performance ecoboost progressive controller ( awaiting pricing)
5- Purple Nylon tubing (if anyone knows where to get water meth tubing in colors I would like purple if you can find it)
6- AEM Water/Meth flow gauge
i. http://www.aemelectronics.com/?q=products/gauges/water-methanol-injection-gauges/water-methanol-flow-gauge
I should have the rest of the parts in my existing snow performance stage one kit. Let me know what you think!
