Megan coilovers for 2013+ SHO/Flex are IN!!!
Mike is coming through as usual!  If I had an SHO, these would be on my shopping list.  Last time I had coilovers, I loved getting to fine tune the ride height to my taste.
I think that Megan also offers different spring rates if someone wanted to play around later.  Is that correct?
With the adjustable struts on my MKS, I think I will need to stick with lowering springs.  I'm not sure what kind of tizzy fit the car would throw if they were eliminated.
Same here, I would miss the soft ride when in D, then just click down into Sport and everything is tight...ish :)
Congrats to all those 2013+ owners, for having this fantastic suspension upgrade option available to them for purchase.
Mike B. , EPP & others should be commended for their resilience, resolve, and perseverance in their unwavering efforts to see this mod come to fruition.
Now start ordering these ASAP!
FoMoCoSHO said:
EcoPowerParts said:
No camber plates available.
So for someone who has never had coilovers, what exactly does that mean?
I'm no expert on suspension but I think it means you will not have the ability to dial in camber and the lower you run them the more negative camber you will have and increased inner tire wear.
