So I installed my Megan coilovers last night. So far I love them. I set the fron all the way down. The rear is set at about 1 1/16 inch up. The rear definitely will go lower than the front if you put them both all the way down. The ride is better than I expected. I came from stock suspension, and it rides about as good as it did before.
If you set the dampening too hard, it still rides good, but gets more harsh and you feel every like bump, overpass transition, or anything else. If you set it too soft all of that goes away, but it gets rough on bigger bumps, potholes, etc. Right now I have the front at 11 clicks from full hard, and the rear at 9 clicks from full hard (The new sets are 15 way adjustable, instead of 32 way). I am pretty happy with this, but will be toying with it some more. For the track, I will be turning the stiffness up in the rear.
Here are a few pics...
Before:
After:
And next to the wife's stock Flex for comparison:
Before:
After:
