ZSHO said:It has been roughly a year since having my Alky meth pump kit installed.. The other day had no choice but to take the vehicle to an auto car wash due to unexpected salt on the roads which I seldom do..
Today noticed a small puddle right under the front driver's side bumper and verified that the Alky pump is leaking once again!
I guess lesson learned is To avoid Auto car washes at all costs,especially during cold winter freezing temps.
I hope this helps someone out in the very near future. Z
Original Intention was to seal up the exposed area against water intrusion and the elements.. Dunno @ the moment.Thanks SBS. ZStealBlueSHO said:ZSHO said:It has been roughly a year since having my Alky meth pump kit installed.. The other day had no choice but to take the vehicle to an auto car wash due to unexpected salt on the roads which I seldom do..
Interesting... maybe time to change location of the pump?
There is ONE section in that vicinity that is susceptible to water intrusion and my guess is the combo of the freezing temps and the under-carriage auto wash was not welcoming. Zlamrith said:Any idea what it is about the auto wash that caused the leak? The pump is in an area that should be protected from the brush/cloth and sprayers for the most part?
Bummer she is down again, Sorry to hear it Z.
Still need to take the internal gizzards apart.bamsho said:Z is the pump itself leaking or at the fittings
Which controller did they use in your car? I’m curious as they didn’t use an Alky controller in a local SHO’s DPM car...ZSHO said:New Methanol Filter and 90 degree elbows to Alky pump arrived today. Hopefully can finally complete long awaited install. Z
https://www.alkycontrol.com/shop
Alky controller IIRC! It's NoT a Progressive controller found on newer setups. ZStealBlueSHO said:Which controller did they use in your car? I’m curious as they didn’t use an Alky controller in a local SHO’s DPM car...ZSHO said:New Methanol Filter and 90 degree elbows to Alky pump arrived today. Hopefully can finally complete long awaited install. Z
