I'm in the process of reinstalling my Snow Performance meth kit and ran into a problem getting 12v key on power from the fuse box. In the past I used fuse #50 (15amp) for the heated mirrors. But today it wouldn't power up the Snow Performance controller. I checked the fuse and it appeared to be fine but, I replaced it to be on the safe side. Unfortunately the controller still wouldn't power up. So I connected it to fuse #70 and the controller power right up. So then I took my multi meter and tested the #50 fuse by placing the black wire from the multi meter onto the negative side of the battery and the red wire to the fuse. This test yielded zero volts. I then tested several other fuses and all were 14.3 volts. Anyone ever have this issue or know what should be my next step. Thanks for your time.
