I've been using a 1.25 per 13 gallon mix through winter. Just enough to guard against low octane pulling timing.ajpturbo said:Solid...I really want to try a little e85 now
I really want you to as well so we can get the perfect mix dialed in.ajpturbo said:Solid...I really want to try a little e85 now
I dont think it has anything to do with the E85. The corn and any good fuel has plenty of additives to keep that from happening.SHOnUup said:I've been using a 1.25 per 13 gallon mix through winter. Just enough to guard against low octane pulling timing.ajpturbo said:Solid...I really want to try a little e85 now
FoMoCoSHO would have a better gauge on the most effective range. But I think I remember him saying something about a sweet spot at 15-20%.
HPFP has gotten louder over the course of the mixing I think. Gonna try some MMO, Marvel mystery oil to help lubricate.
Thx
Rich
SHOnUup said:Cut those intervals in half if using a 70% E 85 too right?
That's the ultimate variable I think. Seeing a sticker on the corn pump saying 70% minimum makes me wonder.
Rich
ThxFoMoCoSHO said:And congrats btw!
Idk, I ran corn for 20k on the 2013 all the way up to 65ish % and never saw a misfire logged.SHOnUup said:ThxFoMoCoSHO said:And congrats btw!
With the more potent corn, I think my random misfire came because of fueling up with too little fuel in tank. Throw that corn on less than 40 miles to empty and I think it sucked in a potent chunk? Only thing I can think of.
Rich
SHOnUup said:Non PP
DA 650...Livernois 4x plus 93...Windstorm cai...15.5% E...3bar
Rich
Thx buddy.BiGMaC said:SHOnUup said:Non PP
Rich
Congrats Rich!!
I get misfires and rough idle when I go from plain 91 to anything over 20% corn. At least for the first few miles till it adjusts.SHOnUup said:ThxFoMoCoSHO said:And congrats btw!
Rich
Thank you.wasinger3000 said:I get misfires and rough idle when I go from plain 91 to anything over 20% corn. At least for the first few miles till it adjusts.SHOnUup said:ThxFoMoCoSHO said:And congrats btw!
Rich
I put in a gallon of meth with 9 gallons of 91 and it was not happy for awhile. A few miles later it was like normal.
Congrats on the new time!
Thx buddy.Larrylu said:Pretty slick for such a youngster Rich! Impressive.
Yeah it is not a fun feeling. Mine happen after a wot run so I thought I broke something. I pulled over to look for any fluids pouring on the ground hah.SHOnUup said:Thank you.wasinger3000 said:I get misfires and rough idle when I go from plain 91 to anything over 20% corn. At least for the first few miles till it adjusts.SHOnUup said:ThxFoMoCoSHO said:And congrats btw!
Rich
Appreciate the share on the misfire experience. It's had me pulling plugs, checking all piping and hoses, cac, PTU again(don't know why I checked it again...at a point in staring at the car thinking of what to check next...you just do sonething...lol), coils, MAP sensors, intake....etc
Sensitive sensors all over the place in these complicated things I see.
After misfire I reset the codes and car drives perfectly normal. Weird
Rich
That would be scary at or right after a WOT run.wasinger3000 said:Yeah it is not a fun feeling. Mine happen after a wot run so I thought I broke something. I pulled over to look for any fluids pouring on the ground hah.SHOnUup said:Thank you.wasinger3000 said:I get misfires and rough idle when I go from plain 91 to anything over 20% corn. At least for the first few miles till it adjusts.SHOnUup said:ThxFoMoCoSHO said:And congrats btw!
Rich
Rich
Now I just drive around nicely if I make a radical change in corn. But I'm usually at 15%.
