Only gained two tenth by adding livernois meth kit!
skinny
I have a 2014 sho nonpp with livernois tune downpipe exhaust and 3bar and was running 12.7 mostly on all my runs! Then I decided to add the meth kit from livernois and have took it to the track three different times and the best I could do is 125! Don't know if I'm doing something wrong do I have to hit the test button once before I run it? It dyno at 395 and 444 tq. I appreciate any help with this meth thank you
My 60 ft was 1.910 1/8 was 8.1396 at 87.63 mph 1/4 mile was 12.5839 at 110.70 and I launched at around 1800 rpm
Does anybody with the livernois kit have any ideas for better times ? I have it set at around 6 and don't know if I should hit the test button before a run? I have lowered front tires to about 28 psi seemed to get better times that way and also seems to like launching around 1800 rpm! Thanks
I'd call Livernois.  They will have no problem helping you dial in one of their products and will have the best info on what you need to do.
Skinny what exact tune are you running?Did you request a tune for the meth?tire pressure 22f&24rear and remove the engine cover and a quarter of gas in the tank and try to launch above 2200.
I always have less than a 1/4 of a tank and a have been taking off engine cover! I will try that tire psi do you have meth on your car?
What exact tune do you have and did you request LMS a tune for the meth?Plugs have to be gapped at 0.30& do you have a cooler stat on your car and meth will be my next project and good luck with the ride.
Running 12.5's with those crappy 60 foot is pretty good. Makes me think there is a grip issue here, guessing there is a lot of spin. GYF1 Supercars? I was dropping my PSI's to between 24-26 and still had too much spin at a well prepped track.
I had my car on the dyno at livernois after meth I don't have to gap plugs for the 2014 sho they have it dialed in pretty good 395 hp and 446 tq
I am not home right now to pull up my time slips. But what temp did you run the 12.5 at? And what was the DA at the track? You can go to DragTime.com to get that. But long story short  1) At 85deg at LMS track day (1 day after a dynotune of 405 HP/417 tor) I ran 12.44 because the DA was 2100!!!!  2)  in Ga. @81 deg/DA 1700 run 12.33!!! 3)  At a better track in Ga , TUNE-ONLY @59 deg/DA 700 I ran 12.669 ( NO 3-BAR or Nothing!!!!!) So temp and DA makes a lot of different even with METH!!!!!!
That was my first time at kilcare it was last Friday they had the street life tour going on! I usually go to edgewater I go with a bunch of guys that have new Shelby's and 5.0 mustangs we all work at ford motor company in sharonville I'm trying to get them to come to kilcare this friday
Dammit, I was going to go but I loaded a new tune and the car wasn't trimmed out yet.
Let me know if you are going, I work out that way and I should be off around 7.
The more Fords kicking ass the better!
Sounds good I got to get some more track Time and get this meth figured out I spent too much money on that only to pick up two tenth but I appreciate everyone help!
+1
What's your tire setup? I just swapped out the crappy OEM Michelins for a brand new set of Toyo Proxes Plus 4, day and night difference.
Yes I have the Michelin but my sho is 2014 and tires are still pretty new but when I'm ready for new tires the toyo are the ones to go with?
