Part identification
klrsmith
Good Morning!
Can anyone help me identify these 2 parts and part numbers - this is a 2014 PI.
First one is a small box with a big relay attached to it, this part was originally connected to the firewall side of the degas bottle (both parts connect together) I had to move it when I put in the OCC.
Second one is a hose from the intake all the way across the firewall to the driver side.
https://imgur.com/a/91xHd
Thanks for the info Z. That vacuum hose is definitely what I was looking for.
As for that degas mounted electrical box with the relay on it, I do have the truckmod guide for the 2014, but I don't see that part in either guide.  There is a ford part number on it, but it doesn't seem to come back to anything that would remotely describe it.
Thanks again for the assist!
@- klrsmith It's my pleasure.  :)  I guess you also got me thinking. :hmmm:
What's the actual part number ?  I can try to cross-reference the part for ya.
Is there any type of bracket holding it in place ?  Z
The larger main part shows DG1T-14A099-AB on it's outside cover.  The Relay inside under a separate cover shows AW7T-13350-AA and I think (I can't get in there far enough to verify without taking stuff apart) but it seems to be part of a wire harness which has a EG1T-14290-KB barcode tag attached.  Oh the bracket on this part is made to fit into the cutout on the degas bottle - they are literally made to fit together...
At least I couldn't find anything with those PN's - If it was part of a lighting package wiring harness, I would know that it's cool to remove it... but the lighting packages listed in the options of course only have a 3 digit option code.
Cool, that's a great site - I would guess this piece is part of a PI lighting package, part of this (at least very close harness) - EG1Z-14290-KA - "HEADLAMP PREP PACK, WIRING PREP, With Level 3 Headlamps, With Level 4 Headlamps".  Tracing this harness down, I should find disconnected connectors or just cut cable - if so I'm planning to remove it.  Already tight working on these freaking sideways mounted engines :-)
