TouchOfEvil
This is my first FI vehicle to own "explorer sport" so i'm new to it but i believe i am getting spark blow out.
I can't tell if it does it in first because the gear is short and it wheelhops insanely bad on the 1-2 shift.
In second gear and third "didn't get into fourth" the car feels like it is sputtering, i could hear what sounded like pop pop pop then i let out. It is a little colder tonight than it had been. The coldest i had seen was 63 degrees tonight when i left it was 55 degrees and it did the stutter and pop thing and it got down to 46 degrees and of course the problem did not go away at any point.
I am running stock plugs but they were gapped from the factory at .30, i did check them to verify the gap.
I'm in louisiana so i'm sure my climate and da are way off compared to anyone up north.
Does this sound like spark blowout? Or is it something else?
Current mods are as follows:
Drop in k&n filter
170 t-stat
3rd cat delete
magnaflow x-pipe with mufflers
livernois 93 hi boost tune
Any help would be great.
Drop in k&n filter
170 t-stat
3rd cat delete
