mystery101
Noticed some vibration and road noise / rattle on bumps. Found the factory LCA bushing torn and replaced the whole arms with Moogs.
Since then the whole front end seems to act strange around corners that varies with throttle input; You can go around a corner and the whole front end feels like it is stepping sideways either direction and will suddenly change under a shift causing me to have to "overcorrect" the wheel in the opposite way.
Car has been to two separate dealers for an alignment and an independent alignment shop after the fact in an attempt to identify or mitigate the issue.
All 4 wheels seem tight and pass the side to side, up down test off the ground..
The only thing I can think of is maybe I didn't torque the balljoint nut down enough; but it seemed like every time I added leverage to the end of the wrench it would turn more and I felt like was getting close to being overtightened. Both front LCA bolts are tight aswell.
Fitment issues with moogs possible?
