Smoke out the exhaust
BOOSTD SHO
Just received my 13 SHO from Livernois on Friday evening.
My car has the upgraded turbo wheels, tune, full exhaust, and methanol injection.
Under part throttle - WOT the car will smoke like a diesel, and upon deceleration, it will pour white smoke out the exhaust.
The fluids look "normal".  Does this sound like the turbo seals are bad?
The car dyno'd at 403 with the 93 tune, and 414 with race gas.
The car has 800 miles on the clock.
Thanks for any guidance!
Mike
I hope it's not white smoke, that's really bad, it indicates you have a bad head gasket or somehow water is getting into the exhaust. I would expect blue smoke due to the turbos smoking.
Here's the normal scenarios for colored smoke:
Blue smoke indicates burning oil (this is the most common). If the car is older, or has high mileage, than most likely the piston rings have worn down and oil is getting by the piston as it moves down the cylinder wall. It then gets burned with the fuel, which produces the blue smoke. The faster you go, the more smoke pours out of the car. If this is what's happening, keep an eye on your oil level. You will definitely have to add some between oil changes. This would be very expensive to fix, so I would recommend continue driving the car and adding oil, but start saving up for a new one.
White:
White smoke is not such a good thing. It means that coolant/antifreeze has gotten into the cylinder and is burning with the fuel. This should not be happening. If your car is burning white smoke (not just the white exhaust on a cold day, but consistently produces white smoke), first check your coolant tank and monitor the levels for a while and note if it's going down a lot. You should also look at the coolant and see if oil is mixing with it. Also pull out the dipstick and look for coolant that was contaminated the oil. Look for green spots on the dipstick, or an oil consistancy of chocolate milk. If the coolant is mixing with the oil, and you continue to drive the car, the car is not getting the proper lubrication it needs, and the engine can sieze at any minute (this will junk the car). The mixing is caused by a blown head gasket(most likely), possibly a blown intake manifold gasket, or worst case scenario, a cracked head. If the gasket is the problem, your looking at about $700 in a shop.
Black:
If you have black smoke coming out the end, it means that too much fuel is being dumped into the cylinder, and not all of it has the chance to burn. This is caused by a faulty fuel-management computer, fuel pump, a faulty injector, or on older cars, a poorly tuned carbeurator. This is cause for the least concern, and usually just means you will get bad gas mileage. I would still have it checked out eventually.
Thanks for the info.
It is all white smoke.....
It smells like pure oil burning, but the white is a bad sign.
I have put 120 mile on it from Friday.....
Looks like it will be going back to MI.
Mike
Mike
I would bet it's turbo seals, I will hope for you  that is what it is, oil smell and smoke is usually that.
Sent from my phone with lots of misspelled words...
I think darreli had HD turbo seals installed, no?  Could also be the methanol kit is malfunctioning in some manner.
I'm with 4DR...bet its the turbo seals. Mine leaked at one point and I had the same s/s. That was one of the things that prompted me having the turbos re-worked when I did. Tial does but better seals in with the "upgrade".
12sho said:
it might just need to burn off the oils from the new exhaust and turbos.
This is a possibility, but I would think with the 120 miles and a couple dyno pulls that it would be gone by now...
I would look at turbo seals.  My truck would smoke light gray/white/blueish smoke on decel when my turbo seals too a sh!t...Hard to tell on acceleration if it smoked since it is a diesel.
Are you sure it is white smoke or a does it have a blueish hue to it?
All,
The smoke is so prevalent that after I run it, I can come to a stop and go see the tail pipes and it comes out a pure white and smells just like burning oil.
The car runs great, just the smoke is the immediate concern.  This is why I feel the seals or something internal to the turbo upgrades are the issue(s).....
Thanks Again!
Mike
Andy from Livernois emailed me and mentioned that the new turbos may require as much as 800 miles on them before the turbo seals properly seat.  I currently have 130 miles on her from getting the car back.
All the fluids look great, and the levels are all good.
I am hopeful that this will be the case!
The car runs great!  Still getting use to the Corsa exhaust......  sounds a little rice'ish.
Once my confidence is up I will take it to the track to see how fast she is!
Thanks All!  Great forum!
Mike
After having installed dozens of turbos over the years, I've never heard of such a thing.  Never had to wait for turbo seals to seat.
I was thinking the same thing, if you're having issues with turbo seals out of the box they're bad...
Ask Darreli about Andy......
I also had an issue with him over the serpentine belt with the underdrive pulley I purchased from Livernois. Sent me the wrong one.. He argued with me and eventually allowed me to send it back for a refund at MY expense.  Overall cost extra due to his mistake... at least $50.
Rick was great.  Can't say enough good things about him.
(strangely, I am of the similar opinions........)
Time will tell with the seals.
Hope they need to swell, seat, or whatever.
Car runs great!  It feels like it may be a solid low 12 second car.  Keeps pulling and pulling!
Mike
I was on the interstate today, and I thought you were in front of me, pulling a trailer, but it turned out to be a Chevy Diesel Pickup -  Constant smoke!
I surely hope you get it fixed or it fixes itself.
Now have 2200 miles on the car, and it smokes like a PIG even more.
Fluids look OK, just the dipstick is dropping, and I am adding oil......
Looks like the turbo builder is hanging me out to dry on this.....  The car had 174 miles on it and they installed the new wheels, but did not change any of the seals, and appear to not have any interest in making the car right .....
Does an aftermarket company make a complete turbo upgrade yet?
Not happy with the car so far, due to the lack of any definitive course of action from the $11,000+ I spent and the 6 months at the shop....
Irritated!
What shame! I don't know what the standard is turbo shops as in a warranty for there workmanship. Apparently there is none, well what every problem is. Its probably only one of the turbo's, I just can't believe no one is stepping up to the plate to make it right.
