Snow Performance Plug and Play Meth kit for F150 Ecoboost
4DRHTRD
Just saw this on my Ecoboost news feed, I've got an email in to them to find out my cost so I can put on my site.
Finally a cost effective plug and play meth kit, their meth kits are also 100% meth compatible. I'll be buying one for my wife's truck very soon!
I'll also be making sure my charge pipes have a port pre-TB for meth injection.
I'm begging them to make one for the transverse guys as well.
Want more power and better fuel economy from your ’11-to-present  F-150 EcoBoost? Check out Snow Performance’s new Stage-3 Boost Cooler water/methanol injection system. The Stage-3 kit features a plug-and-play harness for easy installation, digital two-dimensional controller, and an LCD display showing boost, fuel injector duty-cycle, and injection pump output. Retail cost is $699.
It looks to be direct connections as opposed to splicing into wires. The pump/fittings other than the electrical ones look to be exact same.
This is my first post after reading this forum every day.  I have a 2012 EB Flex.  Please don't move to new member thread.
On the Snow Meth injection you need to be aware that the MPG kits do not do what they advertise.  They make it sound like they inject at all power settings.  I just purchased a kit for my diesel RV.  In the kit is a warning not to run the system all the time or controller or pump will fail. They instruct to adjust the system to come on at 2 psi boost above cruise.  Right on the pump Aquatec it says not for continuous operation.  They also told me on the phone the same thing.  It seems after some internet research that they had controller failures due to overheating, instead of fixing the controllers they changed the setup and continued to say that they injected all time.    I am disappointed in my purchase of their kit and thought everyone should know about this before purchasing a kit.    Dave 2012 Flex EB Titanium
Glad you said that. I was looking at getting that kit for my car to see if it raised my mpg at cruise speed. Thank you for the heads up! Welcome to the forum!
No water/meth system sprays all the time, they are on demand systems. In my car my system begins priming at 5lbs boost and sprays at 8lbs and pump speed progressively ramps up from there.
