SOLD!!!
$200 = AJPTurbo Wastegate Boost Spike Control Mod.. Includes:
- TiAL MV-S Sport 38MM Wastegate and original accessories.
- Blue and Yellow spring kit already installed.
- Custom Dump Pipe with V-Band Welded
- Pre-Cut hose and clamps needed to connect it to the Noise Maker outlet.
- Pre-cut and spliced vacuuming hose. This is a direct swap out of the vacuum line with the T connector installed and extension vacuum line added for the signal to the wastegate.
-DOES NOT INCLUDE ALLEN WRENCHES SINCE THE KIT DID NOT COME WITH THEM. IF YOU DON"T HAVE ALLEN WRENCHES YOU PROBABLY SHOULDN'T ATTEMPT THIS MODIFICATION...
One of the screws that holds the top of the wastegate down broke off during a spring a replacement. This is shown in the picture, does not affect the performance.
Link to the modification: http://www.ecoboostperformanceforum.com/index.php/topic,6526.0.html
UPDATED - I will also include the Dawes Devices MKII Manual Boost Controller that you can add in-line with the vacuum signal line. This was MY ADDITION TO THE KIT and NOT AJPTURBO's addition. This modification on top of his modification allowed me fine tune when the wastegate would open and close. This does require you monitor your datalogs for fuel pressure until you dial it in, but allows you more control over the boost spikes. I will include the Vacuum lines for this as well.
http://dawes-devices.com/collections/turbocharged-automobiles/products/dawes-devices-mk-ii-hybrid-boost-controller
