Spark Plugs Wires Boots?
peppelepugh
I'm approaching 55k miles on my SHO and tuning it up this holiday. I've already got my plugs on order and ready to change them once all the parts are in. But i've read up about having a couple spare spark plug boots on hand. Just wanted to check with the community about the part number and make sure i have this one correct. "MOTORCRAFT Part # WR6135 {#BL3Z12A402A}" (pulled from Rock Auto)
Second is spark plug wires.
I figured since I'm already tearing into things enough, i should change the wires too since a rough rule of thumb is like 60-75k miles i've always heard. Any recommendations?
Thanks in advance!
I don't think there is a specific mileage range suggest for COP wiring (not being high voltage like conventional ignition), but no harm in doing them if you prefer to.  I'd check resistance on the wires and how they looked (cracking, corrosion, stiffness, etc.) before replacing them.
http://www.aa1car.com/library/copign.htm
Thanks for the info guys!!!!
I think i'm going to order at least like 3 boots to be on the safe side. Rather be safe than sorry. I normally work on my car on a sunday.... when the parts department at the dealership is closed.
