So here's my issue. My latest data showed zero cooling and low FRP even though I'm injecting 100% VP Fuel M1 (methanol). I check the system under boost and it's spraying meth as it should. I initially thought the pump failed but during my test the pump worked fine. Then I thought my meth went bad again. So I purchased a new 5 gallon metal can of methanol instead of having them pump 3 gallons of meth into my VP Fuel plastic jug. Apparently after my call to VP they don't recommend storing meth in a plastic container do to moisture issues. So then I drained my tank in the car and refilled it with new meth. I did see some improvement in the cooling. I did several data logs and the cooling is inconsistent at best. There was times where I saw zero cooling effect even though it appears to be spraying. I only say it's spraying because when I'm done data logging I have to add approximately 20-25 oz. of meth back in the tank to fill it up. I always top off the tank with meth prior to data logging. So now my issue remains with no cooling although it appears my meth system is spraying meth. Any one have any ideas to what might be going on...
Here's a couple of logs... Thanks for looking
