Spring Rates
Wild13SHO
Anyone know the spring rates for the SHO, preferably the PP.
I pulled the rear springs out to put in the Eibach lowering springs and the rate of the stock PP springs appear to be much higher.  I'm going to contact Eibach to see if they will provide the spring rate.
Eh; would the rate be higher because you are putting in lowering springs?
Excellent, where did you get that info from? Thanks
I wonder if there is a difference with the standard SHO and the PP?  I know my springs have a PP label on them, so I'm assuming there is a difference.
Yes; I'm told that the PP got stiffer springs than the non-PP SHO.
