staged_sho said:
FoMoCoSHO said:
staged_sho said:
Curious those of you who monitor/log, what you've seen as your boost levels under wot stock. I've flashed back to stock, and seen boost go up to ~12psi briefly (which is expected stock) immediately after flooring it, but it falls between 10-11 during the same wot run.
I'm into the 14's at times...
Stock? I'm wondering if there's a leak I need to look for. I do hear more induction noise than what I remember...prior to tstat install...and bg service.
Stock besides the E-85 blend, but it changes as boost is dependent on lots of variables.
I'm not sure what effect, if any, the corn has on peak boost #'s.
