Torque Source...
16MagSport said:What did the log show? Did the advance and/or throttle blade angle drop or swing wildly at the time, differently than a smooth shift? Sure sounds like wheel hope since it goes away with a softer shift. Did you feel torque steer on the shift as well?
16MagSport said:Much warmer means the tires are softer. They'll hook harder but if they do spin it may be smoother. Pay attention to the road conditions too when it happens. Some roads are stickier than others. Did you have torque steer? I know my wife's Explorer hopped and would jerk with torque steer. That tune had all torque management removed and huge boost spikes. Brad's is nice and smooth. I like that because I can go WOT with the fam onto the highway and it is smooth and I don't get yelled at. If it was hopping and jerking, the wife would be a little upset. I was disappointed that it did this hopping. The damn AWD should keep that from happening. If it was locked in a 50/50 power split then it couldn't hop the front tires. I wish it wouldn't let the fronts spin faster than the rears when at WOT.
TSS said:The stutter feels like the car tries to switch gears but misses it (doesnt catch)on the first or second try. I know that's not very descriptive, but it's an awful feeling that makes you think something really bad is happening.
16MagSport said:Strange. If you didn't feel anything in the wheel then it wasn't hopping. Well, I would just run the softer shifting tune and not worry about it. Hopefully it just means that it is unhappy with that higher pressure. Makes you kind of wonder if the pressure should be dropped more for some safety margin.
Brucelinc said:The stutter has been described as the car attempting to shift - not shifting - attempting to shift - not shifting and then shifting - all of this in a split second. It is a bit of a mystery why some cars do it with high shift pressure and some do not. It is also odd that in several cases, new fresh fluid eliminates the issue and in other cases, it has no effect.
As Todd and I have both confirmed, lowering the pressure to prevent it does not hurt acceleration.
TopherSho said:Brucelinc said:The stutter has been described as the car attempting to shift - not shifting - attempting to shift - not shifting and then shifting - all of this in a split second. It is a bit of a mystery why some cars do it with high shift pressure and some do not. It is also odd that in several cases, new fresh fluid eliminates the issue and in other cases, it has no effect.
How fast is the shift being commanded if i may ask. I am at 200ms.. and am curious if 180ms is to much.
TopherSho said:Ya know whati'm feeling cheeky so i will do just that
