Tire Rub
WickedSHO
Hey guys...So I have noticed over the last few weeks, that when I have the wheels turned all the way to the right, the front driver side tire is rubbing on something.
Anyone else ever hear this?
I my car the wheel well cover was fairly loose,as i recall tightened all the bolts with a 6mm socket and a phillips,there are two covers inside the wheel well,one could of came loose,with the car running turn the wheel both directions and tighten the bolts and screws,but not to tight and do the same for the rear,also check with a flashlight if there are any leaks from the struts,if so call your service advisor asap.
