Have any of you been low on Transmission Fluid?
I checked it the otherday when I changed the air filter, car was clold hadn't ran for hours ( I know you are supposed to check when hot) was expecting to at least see a little bit on the dip stick but there was nothing. So I checked it the next day as soon as my wife got home from work (30min drive on 90° day ) since I new it would be hot. When I first pulled it out I could see trany fluid but couldn't get. Good read of level so wiped off put back it. Pulled it out and nothing. We have had absolutely no transmission issues or signs of leaks. This is first time I have checked it, since it was wifes daily she had dealer do all checkups, ect.
It obviously has fluid but is low seems very odd, is this the way it has probably been then whole time?
Thought I would share this weirdness. I will be toping it off and monitering for loss over the next little bit
