Undercover tray/splash guard
ecoboostsho
Hey everyone...I was changing the oil yesterday and the cover on the bottom of the engine was hanging down in one corner.  Sure enough it was missing one of the twist lock/screws that hold it to the body.  The "nut" retainer clip is still there thankfully.  Does anyone know if I can get just the twist lock/screw without buying the whole cover?
Tasca doesn't seem to have it - just the entire cover...
https://www.tascaparts.com/oem-parts/ford-under-cover-da8z9910494a/?c=Zz1ib2R5JnM9cmFkaWF0b3Itc3VwcG9ydCZpPUpOMTAwMzA1JnI9MTAmYT1mb3JkJm89dGF1cnVzJnk9MjAxMyZ0PXNobyZlPTMtNWwtdjYtZ2Fz
I'm not buying the whole thing so if I have to I will just make do with a push clip for now.
Thanks!
Anyone have a part number for that under engine cover splash tray/guard?
Sent from my SM-G950U using Tapatalk
ZSHO said:
Ok just making sure the 2016's are the same as 10-12's. I think they are all the same but you never know with Ford. From my memory it seemed like my old 2012 SHO had the same under engine cover as my 2016
The 2010-12 use Ford Part # DE9Z-9910494-C .The 2013MY & Up calls for part # DA8Z-9910494-A which look similar but different in design AFAIK. Z
