UPR Dual Valve CC with CSS Issue
StealBlueSHO
Administrator
Staff member
Ok... I installed this awhile ago and I don’t get much crud.. maybe a table spoon or so every 3K miles when I change out the oil....
Now, I have noticed I am getting more oil in the intake track than I like.. I originally noticed the oil build up when swapping the hot pipes.. and really noticed it after the EPP dual feed..
Prior the UPR CC it was dry...
Thinking about pulling it and throwing the stock stuff back on to see what happens..
Just for reference, mine pulls about an 1 ounce of oil per 1000 miles. Since my ownership starting at 50k miles my hot side had oil in it prior to installing my UPR DV CC with CSS.  Removed some oil when in the hot side tract when I installed the noise maker eliminator, and pulled about 2 oz out of my stock IC as well.  It has been significantly less with the CC on for the past 25k miles.
Update...
After this post, I found that the check valves were not tight and leaking oil.. which also means the vacuum and pressure would be off... so I cleaned everything, tightened it back down, and reinstalled.
Fast forward to Friday the 4th of December...
Leaking oil at the bung on the dual feed and oil is coming out the oil fill tube caking the underside of the CSS...
I pull the tubing and oil is pooled in the tubing, it’s pooled in the intake track, etc etc...
So from what Matt was telling me the dual feed pcv doesn’t have the correct vacuum setup which is why Mike Bambic released a fix. However the fix which is a metal tub with a diagonal cut needs to be welded in to prevent it from turning in the tube and creating additional pressure...
So my options are to keep the dual feed and ditch the UPR setup... or keep the UPR setup and go back the AIRAID setup...
For the moment I have pulled the UPR setup and threw the stock tubes back on.
I had problems with the new oil cap breather blowing off I got hit in the face once with it lol 😅, and the next time it blew off near my house and put a hole thru my hood lining I contacted them for a cap and Insert that screws in instead of the new push in style if that’s where it’s leaking for you. They where very helpful, they told me it was due to excessive blow by. That will be fixed soon tho.
Interesting.. I question their response on the excessive blow by.. I suspect there is a imbalance on the setup creating too much pressure.
I agree on the pressure. I have the original Tracy Lewes set up, not upr. I have zero problems. It is giant and in drivers side wheel well. I get maybe 2 tablespoons oil and half a cup gas water mixture per oil change,  slightly more in winter...
I may need to check if oil is pooling in my lines. I noticed a film of oil under the clean side separator. Where does this tube with the diagonal cut need to be installed? Do I need to contact Eco Power Parts?
Yes contact @ecopowerparts.
The tube will need to be welded in place.. if it spins around it will cause additional pressure which is a
Big no no...
It drops down into the pcv bung on the dual feed.
