jmr061 said:
ShoBoat said:
I had this TSB done on mine, if you can get it done under warranty do it! The new seals are way better then the old ones.
Which TSB did you have done? If it is the rear door scuff thing I would like to see pics of what they did/whats different now?
DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES
Publication Date: November 17, 2011
FORD: 2010-2012 Taurus
ISSUE:
Some 2010-2012 Taurus vehicles may exhibit road dust accumulation on the rear door scuff plate area.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Paint the replacement body quarter trim panel from the Dust Kit to match the vehicle exterior color.
Install the Dust Kit parts. Refer to instruction sheet included in the kit.
PART NUMBER PART NAME
AG1Z-5420530-D Dust Kit
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
111120A 2010-2012 Taurus: Install The Revised Weatherstrip Kit Following The Kit Instructions. Can Be Claimed With Operations B And C As Necessary 2.3 Hrs
111120B 2010-2012 Taurus: Additional Time To Prep and Paint New Molding Assemblies. Can Be Claimed With Operations A And C 1.5 Hrs
111120C 2010-2012 Taurus: Additional Time For Vehicles With Tri-Coat Finish. Can Be Claimed With Operation A And B 0.5 Hr.
I'll see if I can take some pics of what was done. But pretty much all of the lower weather stripping on the car and the door weather stripping also.
