Will they fit????
Yes, they will  fit, however, your tire option will be limited. The widest tire you may fit might be 245/255, depending on manufacturer, if you go with factory sidewall height. You would be better off getting something around 35-38 mm offset.
I have 255 40 20 tires on stock pp wheels now.was going to just swap them.will these wheels stock out farther then stock or sit in more then stock
