ChrisxHowe
Member
Well pretty sure my 8 day old XDI 35 HPFP has failed...I did a pull today and I felt the car bog thankfully I was pretty much home, I parked and at idle I’m only at .35MPa rear fuel pressure I took off a little up my drive way and at 1800rpm it maxed out at .45MPa also had a P0087 code.
Loaded different tune same issue
Just got done installing the stock HPFP and everything is fine and running good
My next step I guess is trying to get ahold of XDI for warranty really sucks I was on my 6 revision and Flex was moving out! Car felt so strong
