Brucelinc said:
Stealblue, when was the last time you changed your transmission fluid?
When I first experienced the 1-2 shift shudder a couple of years ago, I asked for and received a tune with less trans hydraulic pressure. That solved the problem but I missed the shift firmness. I was also puzzled as to why it was great for 15,000 miles or so with the higher pressure and then began the shudder all of a sudden. I changed my trans fluid and put the original tune back in. The shudder was gone and the shift firmness was back like I liked it.
Since then, I have changed the fluid annually and never had another shudder - including multiple back-to-back runs at the track.
Was it the fresh fluid that solved the issue or was it just a freaky fluke? Maybe just reflashing the tune somehow "fixed" it? I really have no idea.
Good question, I had all the fluids (PTU, Transmission, RDU, and Motor) changed/flushed 3K miles ago.
I just got back from the shop this morning to verify they used to correct TYPE of fluids, which they did. The only concern I have is they used Cam2 full synthetic performance fluids for the tranny and RDU, which is obviously not Motorcraft, I specifically asked for OEM fluids...they informed me that they used OEM equivalent!
I have been using this shop for a long time, the master mechanic is one of my best friends... they got a new manager which I think screwed me? Dunno... not a fan of word smithing to get what you want or imply something that it's not..
http://www.cam2.com/products/Automatic-Transmission-Fluid/CAM2-Dexron-VI-Multi-Vehicle-Full-Synthetic-ATF.html
Googling seems to say it's good stuff..
Even so, I can't image fluid breaking down that bad in 3K miles...
I am tempted to do a drain and fill with motorcraft... although I doubt that will change much..
I have various tunes from LMS, AJP, and Torrie...
The ONLY tune that causes the stutter is the 4+X.... and it's not right away... once the transmission does it's adaptives does it happen... I reflash.... goes away for awhile...
