AJP turbo said:
How do you know the CBV(blow off valve) went off? You don't have that logged.
But your wastegates did open on the 2-3 shift which will also cause the boost to drop quickly. When the ECU wants the wastegates to open the wastegate duty drops.
You need to log torque source to see what type of tq reduction if any is being commanded.
You have something a bit strange going on where the boost is being told to be dropped during shifts but it doesn't appear to be a type of torque reduction because your spark is not dropping during the shift.
Lowering commanded boost is not necessarily the same as torque reductions
Nothing appears to be wrong mechanically....But something in the tune is telling the boost to drop, then the wastegate duty is dropping to try and make the actual boost match desired boost.
You always need to look at desired TIP before you start to think there is a problem....In this case it looks like the boost is being told to drop dramatically on the 2-3 shift...Only your tuner knows why....Or at least you hope he knows why.
And there was a data disruption and that's why the speed skips from 83 to 90....It happens.
I only know it went off because the I heard the BPV's (I have then VTA)
Maybe I should make another config file to datalog when I'm at the track I'm only using the config file that Torrie gave me to datalog
Sent from my Pixel using Tapatalk
