i have looked at the
first log, main thing of note is the knock you see in 1st and 4th gears. very little knock in first but noticeable in 4th, after a downshift. good thing is no knock on acceleration. fuel trims look fine for oem tune as it will run pig rich at times with an 0.7 afr when more fuel is demanded. i still have to graph throttle input vs acceleration/knock to see if theres anything there, but did you go really wot? looks like gradual acceleration 13s run with as much time in 1st as 2-shift to 4th. will be looking at it some more before moving on to the next log. seems transmission response is off. now whether it is due to pcm or tcm or actual transmission hardware idk.
no wheel hop right?
https://www.ecoboostperformanceforum.com/index.php?topic=7937.0
torque source management
* 0 - Driver Demand
** 1 - Transmission torque truncation
** 2 - Traction Control
** 3 - Vehicle Speed Limiting
** 4 - Engine Speed Limiting
** 5 - Anticlunk Tipin torque limiting or Tipin rate limiting
** 6 - Tipout torque
** 7 - Transmission Shift Modulation
** 8 - Engine Oil Over temperature
** 9 - Target N
** 10 - Powertrain Limiting Protection FMEM Limit
** 11 - ETC FMEM - RPM Guard
** 12 - PATS
** 13 - OSCMOD
** 14 - Speed Control
** 15 - Transfer Case Torque Limit
** 16 - Torque Based Decel
** 17 - VDE
** 18 - Engine Indicated Torque Limit
** 19 - Engine Combustion Stability Torque Limit
** 20 - HEV Torque Reduction at engine start or stop
** 21 - HEV Tipout Torque Reduction
what you seen in wot1
https://forum.hptuners.com/showthread.php?53586-Torque-Truncation-vs-Torque-Reduction&s=a855985b9655119bdfca315a88af5675&p=421188&viewfull=1#post421188
https://patents.google.com/patent/US20070039770A1/en
i am learning alongside you lol hopefully we can figure this out together, but i am thinking when you get the sho tuned, it will fix this problem. lets see.
btw i do not recommend wot until transmission temp is at bare minimum 100f or above. i prefer it to be at bottom of N.O.T. but not always possible. since there is NO active heating of transmission fluid, it will take a lot longer than engine to reach operating temp. i have seen it as high as 15 min in cold winters and 5 min in summers. so add that to your logging. i do so routinely on my vehicles. ford vehicles love fresh fluid and being at good temps before being thrashed.
