13+ lower grill modifications
lamrith
I am working on visual mods to the SHO and am wondering about the lower grill area.  I have a PP so no adaptive cruise.  I believe on the adaptive there is a mesh panel on the driver side for the sensor?  I honestly am curious as to why Ford left them covered like they did in teh non adaptive cruise cars?  They have an obvious shape like they could have or should have been opened up, but then they did not do it?  I am wondering if there is any benefit to opening up the side sections?
At the same time though that will change how air enters the nose of the car and maybe it needs to be channeled at the center where all the cooling cores are?  Could air rusing in there right at the wheel well liners cause problems with the liners?  I can see it as being another way for water and dirt to get in there and make a mess, but visually I think it might be better and it will put more cool air in there to push hot air out..?
Thoughts?
Thoughts?
My dad and I have always been fans of opening the grills up. I never did so on my SHO, but on my mustang I put a termi (03/04 cobra) front bumper on for additional cooling due to a larger opening (and to show off the intercooler). We made a mess grill with I believe gutter mesh, and painted it, it is literally attached by a few zipties in trick locations, to keep bugs out. He did the same type of grill and opened up the lower grill/bumper portion on his 2011 F150 Ecoboost.
I say go for it if you want to. Remove the OEM stuff, rather than modifying it, so you can put it back if you want to.
Oh, and Pics when you do it.
Might be open on the po-po cars, but not sure.
Opening up airflow also opens up more contaminant flow. So I would advise regular cleaning of radiator/condenser/etc. to keep the issue manageable.  A foaming cleaner like used for home A/C works well.
I would be opening up the side parts of the OEM one.  I am not ready or interested in opening the entire thing up.  Based on what I saw under there attaching the mesh I have would be problematic at best with the contour of things.  But I will check again.
That was a concern as well, though it is already open in the middle and I would only open up the small side panels and the middle is already open from factory.
Even with the cover on there has been a few times I have gotten "Radar inactive...remove snow or dirt from area" message.  And my car has only been out a few times in nasty weather.  I would think it would just be asking for more trouble removing the cover.
Thanks guys.  Based on the input here and looking more at pictures I am going to just stick with the center vented area like the car has now.  The line I think will look pretty good once it is done.
