2010 SHO
RagingPenguin
Noticed when I was checking.for. coolant.leak, oil on valve cover. Pull intake.hose off throttle body, lots of oil in throttle body and.noise maker. Notice while.car was idling there was an intermittent rattle. Pulled dipstick, oil covered dipstick, wiped off, oil.levels fine. Do you guys think engine.damaged by detonation, blow by? Or a blown turbo?
I might suggest PCV letting oil into the intake... Food for thought.  The two areas may have very different things causing oil to be found.  In example, could be a gasket failure and PCV.  Never know...
Bet you'll find some in the intercooler/CAC as well!  x2 on the PCV system being the culprit.  The intermittent rattle may be nothing, it may be the oil filter you are using (non-Motorcraft?), or a stretched timing chain.  Change to a low-volatility full synthetic oil to see if it helps decrease the oil in the TB/intake.  If you can reproduce the rattle, can you make a video of it?  What it sounds like on the F150:
https://www.youtube.com/watch?v=GCFekHM6wuI
Found other PVC breather. Check valve is well there, front turbo pipe has very light film, rear pipe by intercooler flex pipe was the same. No external leaks. No funny smoke. Runs normal. Just oil in throttle body. Only thing different is its been driven 15 hours over the last two days, about 4 hours in rain.
Was thinking if the CAC has never been cleaned, is it possible my spirited driving today through the twisty blew five years of crap up?
Maybe look for simpler reasons like loose bellypan/missing fasteners/dropped nuts/bolts.  Maybe some road debris got stuck and resonates on occasion.  Probably not a catalyst death rattle.  Check the underside of the car, basically.
Nothing seems out of sorts. Car is running good. Sight of that oil made me jump. Kicker was I was in the mountains, 12 hours from home plate with no cell service (posted here that night).
Is the UPR catch can a worth while install? I know I'm flushing my CAC as soon as I can!
Still on my plate to do the CAC clean up and a catch can. Car still is running perfect.
Also found my low RPM rattle, atleast so far I've found it. There was line touching the firewall and vibrating against it. Gave it a gentle bend away. So far the low RPM rattle while lightly accelerating is gone, haven't tested my WOT noises yet. Friend from ford suggested taking a look at the PCV and the oil separator (Not sure if that's what it was, he referred to the black box on side of motor closest to firewall by throttle body) So I'll investigate that also.
Also made it pretty clear that if the car was knocking even a little bit it would throw a code.
Had a misfire code for cylinder six, turns out I was a bit careless with my Di-electric goo and used to much. Cleaned the plug and COP and no code anymore.
All good updates so far :), glad to hear it!  Did you want to put up a pic of the engine with a markup of the black box you are referring to?
Black box, took it off, took a look. Seemed fine, air only moved one way, no excess oil.
All the oil I could collect from CAC, Still not to sure where the oil is coming from in my intake. But as mentioned before, all the turbo lines are clean and car isn't loosing oil
Oil recovery method. Worked great. Didn't blow up,
And what maybe the noise my car makes, as I mentioned it only occurs after a shift, which drops RPM, after talking to the ford service manager he had mentioned it was coming from the fuel lines that supply fuel from the pump.. So what I'm thinking is, is this guy starts hammering on the metal. Going to either secure it or wrap the metal tab to prevent the noise.
Will keep you guys informed!
<iframe width="420" height="315" src="https://www.youtube.com/embed/z3Qu9IMOnkM" frameborder="0" allowfullscreen></iframe>
Well scratch the fuel line idea, it seems to have completely removed up my low RPM rattle I was experiencing but it still has my shift noise.
Right now I'm pretty confident the cars engine is fine. Its not knocking and I've got to stop looking there.
Now my attention has turned to the PTU or transmission as the noise is most prevalent under WOT as/after a shift.
New symptoms for little red
In traffic if I allow the car to idle forward by just releasing the brake its started to pulse forward. RPMs are fine while this happens. I would describe it as if the TQ converter is rapidly locking and unlocking, about every half second.
I've searched quite a bit and it seems there was several problems with PTUs for the 2010s, I'm suspecting I should check the fluid and see how it is, the car has never had the fluid changed and its at 56000 miles.
Thoughts?
Worth a shot, looking at the PTU/trans fluids.  If they have not been changed, then it will likely be time to do so.
