2011 Sony upgrades?
VegasClubGuy
Any chance anyone knows of some easy upgrades we can do with the 2011 Sony System? Anyone just swap out speakers? Is adding a sub easy? Not a huge sound guy but wouldn't mind a little bump in what it has now in the volume/bass section.
thanks!
Most that want to just add some bass use an audio control lc2i to get the signal to the amp. Then use your amp/sub of choice.
https://www.amazon.com/AudioControl-2-Channel-Converter-Subwoofer-Control/dp/B01EDFPNSG
Yep. Just use the rear door speaker off the factory amp  to connect the lc2i to so you can choose your own crossover point. If you use the factory sub wires you'll be handcuffed by the low pass crossover from the factory amp.
Run your power and grounds from the battery and your gtg
