12volts yellow/red (5A) + ignition switch, black 7 pin plug, pin 4
Notes: The BCM (Body Control Module) is the dash fuse box, under the driver dash.
Starter blue/white + ignition switch, black 7 pin plug, pin 7
Second Starter N/A
Ignition white/orange + ignition switch, black 7 pin plug, pin 1
Second Ignition N/A
Third Ignition N/A
Accessory purple/green + ignition switch, black 7 pin plug, pin 6
Second Accessory N/A
Keysense blue/gray + ignition switch, black 7 pin plug, pin 5
Power Lock blue/green (test with pass sw on models w/memory) - BCM, black 26 pin plug (C), pin 6
Power Unlock yellow/purple (test with pass sw on models w/mem) - BCM, black 26 pin plug (C), pin 8
Lock Motor gray/brown 5 wire driver kick, harness to rear
Unlock Motor blue/green (models without memory) 5 wire driver kick, door harness
Notes: On models with memory, it is blue/green (5 wire) at the Driver Door Module, black 24 pin plug, pin 10.
Parking Lights+ yellow/blue + BCM, gray 10 pin plug (E), pin 6
Parking Lights- gray - headlight switch, gray 10 pin plug, pin 2
Notes: May need to interrupt the headlight switch ground wire when triggering this wire. It is black/white at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Hazards brown/yellow - BCM, black 52 pin plug (B), pin 32
Turn Signal(L) blue/green (F); gray/orange (R) + BCM, brown 26 pin plug (F), pin 8; black 26 pin plug (C), pin 14
Turn Signal(R) yellow/purple (F); green/orange (R) + BCM, brown 26 pin plug (F), pin 7; black 26 pin plug (C), pin 15
Reverse Light blue/white + BCM, white 32 pin plug (D), pin 13
Door Trigger green/purple - N.C. BCM, black 26 pin plug (C), pin 9
Dome Supervision gray/purple (dome lamp); purple (puddle lamp) + BCM, gray 12 pin plug (A), pin 1; black 26 pin plug (C), pin 1
Trunk/Hatch Pin gray/orange - N.C. BCM, black 26 pin plug (C), pin 19
Hood Pin blue/orange - N.C. BCM, brown 26 pin plug (F), pin 2
Trunk/Hatch Release brown/yellow - release switch, blk 6 pin plg, pin 6 or BCM, blk 26 pin plg (C), pin 23
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm see disarm no unlock
Disarm No Unlock Transponder and ignition
Tachometer grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh ac any fuel injector, white 2 pin plug, pin 1 (3.5L/3.7L TIVCT)
Notes: On 2.0L GTDI models, the fuel injector wires are green/blue, gray/yellow, purple/gray, or yellow/orange at the lower front of the engine, black 16 pin plug, pin 1, 4, 5, or 6.
On 3.5L GTDI models, the fuel injector 4-6 wires are yellow/orange, brown, or green/white at the top center of the engine, black 12 pin plug, pin 2, 3, or 4.
Wait to start N/A
Brake Wire purple/white + brake switch or BCM, black 52 pin plug (B), pin 28
Parking Brake white/purple - parking brake switch or BCM, black 26 pin plug (C), pin 7
Horn Trigger purple/green - horn switch or BCM, black 52 pin plug (B), pin 33
Memory Seat 1 purple/white - driver kick, harness to rear
Memory Seat 2 yellow - driver kick, harness to rear
Memory Seat 3 N/A -
Interface Modules: Not Available
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Power Antenna WHITE (+) RADIO HARNESS
Amp Turn On VIOLET/RED (+) RADIO HARNESS
Amp Location LOCATED BEHIND TRIM ON LEFT SIDE OF TRUNK
THERE IS A SONY DSP MODULE AND A SEPERATE AUDIO AMPLFIER NEXT TO IT - BOTH PROVIDE AUDIO SIGNAL TO THE SPEAKERS.
Steering Cntrls OPTIONAL
Speed Cntrl YES
Radio Security YES - VIN CODED
Security
Battery BLUE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 GREEN/VIOLET (+) IGNITION SWITCH HARNESS
Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger GRAY/VIOLET (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Domelight Super GRAY/VIOLET (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
LF Latch GREEN/VIOLET (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
RF Latch WHITE (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
LR Latch GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
RR Latch YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Trunk Trigger YELLOW/GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Hood Trigger BLUE/ORANGE (OPEN) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
THIS SWITCH RESTS AT (-) AND IS OPEN WHEN THE HOOD IS OPENED.
Parking Lights GRAY (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Convenience
Headlights-Lo BROWN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Headlights-Hi WHITE/ORANGE (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
LF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb VIOLET/WHITE (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb VIOLET/WHITE (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights BROWN/YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
LF Hazrd Bulb BLUE/GREEN (+) AT FRONT LEFT DIRECTIONAL LIGHT
RF Hazrd Bulb YELLOW/VIOLET (+) AT FRONT RIGHT DIRECTIONAL LIGHT
LR Hazrd Bulb GRAY/ORANGE (+) AT REAR LEFT DIRECTIONAL LIGHT
RR Hazrd Bulb GREEN/ORANGE (+) AT REAR RIGHT DIRECTIONAL LIGHT
Wipers-Lo GREEN/VIOLET (-) IN HARNESS AT VEHICLE WIPER SWITCH
Wipers-Hi VIOLET/ORANGE (-) IN HARNESS AT VEHICLE WIPER SWITCH
Parking Brake WHITE/VIOLET (-) AT SWITCH ABOVE PEDAL
Trnk Release BROWN/YELLOW (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Seat Mem 1 VIOLET/WHITE (-) AT SEAT MODULE UNDER DRIVERS SEAT
Seat Mem 2 YELLOW (-) AT SEAT MODULE UNDER DRIVERS SEAT
Remote Start
Accessory 1 VIOLET/GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/GRAY (+) IGNITION SWITCH HARNESS
Neutral Safety GREEN (-) IN HARNESS AT REAR OF GAUGES
SHOWS (-) IN PARK OR NEUTRAL.
Crankshaft Sensor GREEN/BROWN (AC) AT PCM MODULE AT CENTER OF FIREWALL UNDER HOOD
Camshaft Sensor BROWN/BLUE (-) AT PCM MODULE AT CENTER OF FIREWALL UNDER HOOD
Brake Lights VIOLET/WHITE (+) AT SWITCH ABOVE PEDAL
Reverse Lights GREEN/BROWN (+) IN HARNESS AT REARVIEW MIRROR OR IN DRIVERS SIDE A-PILLAR
Horn YELLOW/RED (+) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Anti Theft RX VIOLET/GRAY (DATA) AT PATS RECEIVER NEAR IGNITION SWITCH
Anti Theft TX YELLOW/ORANGE (DATA) AT PATS RECEIVER NEAR IGNITION SWITCH
Rear Defrost WHITE/ORANGE (-) IN HARNESS AT REAR OF HVAC CONTROL PANEL
Heated Driver Seat WHITE/BLUE (-) AT HVAC MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH
Heated Passngr Seat GRAY/YELLOW (-) AT HVAC MODULE BEHIND HVAC CONTROLS IN CENTER OF DASH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock YELLOW/VIOLET (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
PowerLock BLUE/GREEN (-) AT SMART JUNCTION BOX NEAR STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
Driver Mtr Unlock BLUE/GREEN (REV) AT MOTOR IN DOOR
Driver Mtr Lock VIOLET/GREEN (REV) AT MOTOR IN DOOR
Pas Mtr Unlock VIOLET/GRAY (REV) AT MOTOR IN DOOR
Pas Mtr Lock VIOLET/GREEN (REV) AT MOTOR IN DOOR
LF Window Up BLUE/GRAY (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
LF Window Dn YELLOW/VIOLET (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
RF Window Up BROWN/YELLOW (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
RF Window Dn GREEN/ORANGE (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
LR Window Up BLUE/ORANGE (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
LR Window Dn YELLOW (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
RR Window Up GRAY/VIOLET (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
RR Window Dn BROWN/GREEN (-) AT MASTER POWER WINDOW SWITCH IN DRIVERS DOOR
Sunroof Open VIOLET/WHITE (-) AT SUNROOF MODULE IN ROOF
Sunroof Close VIOLET/BROWN (-) AT SUNROOF MODULE IN ROOF
https://www.fleet.ford.com/truckbbas/non-html/2015/PCED_enUSA_2015_EXPLTAURUSMOD_00_020-1.pdf
