2016 sho sct tunning issues
SHOurpp said:
has anyone tried to pull a fuse/clip like the rs to make the car fwd so you can dyno?
My first time on a non-linked dyno, the tech had to pull fuses. He didn't put them all back when we were done.
Short answer is yes, it's possible, but IMO, you're better off finding a dyno with linked rollers, so you don't have to try to circumvent your onboard systems.
Yup, 100%!! There are only two linked dynos in my area, only one is a dynojet...and the wait list is FOREVER long.... that shows you how much better it is to use a linked dyno for AWD cars/trucks
Linked dyno all the way, DynoJet 424 Anyone?
The shop near me has almost no wait currently, IDK how, but I called monday and had dynotime for yesterday afternoon, no hassle. Lucky me I guess.
Try living in Northern Virginia... common statement is "If you see a line just get in it, because by the time you ask what it's for, it's too late!"
Too many people....
who else  is having trouble clearing  tunes from the x4?
go in to derive,
remove tune from device-
this action will delete-
press ok
then it says" error loading tune copy failed "and it still there.
wtf really? after the second lock up derive actually cleared them-but i still cant today
Please keep the discourse family friendly :)
go in to derive,
press ok
then it says" error loading tune copy failed "and it still f**king there.
Have you tried uninstalling the Derive software off the computer and reinstalling from a fresh downloaded copy from their website?
I had a lot of anomalies and that cleared them up at one point.
StealBlueSho said:
go in to derive,
press ok
no but i will
i only loaded it 46 days ago- thats about as fresh as it gets-
I have this issue every once in a while if I flash a custom tune on top of another. Flash back to stock, then delete whatever files you want on the tuner, it should work.
After that flash back to your desired tune. It has something to do with how the device records what is loaded I believe.
that didn't work
par for the course with the x4
sct tuning issues continued................
ok  full factory reset and update has wiped it out clean again
why dont they just tell you that instead of having a menu that shows you can go to and from the device?(IE that only lets you add but not subtract)
I thought they fixed that bug but maybe not...i know they were working on it..you mentioned you had a copy or update performed within 46 days and called it really fresh...that is way outdated.
And sometimes the auto updater for the updater program is faulty....im not talking about the auto updater tab for the actual device
Try to uninstall and redownload the updater program.....does your program have derive on it or sct?
