245/50r20 tires
pmezo33
Just putting this out there because not many people run this size on their cars.  I know most run either 245/45 or 255/45, but not much about 245/50.  It's been mentioned a couple times on here, but not too much info out there.
Just put these general altimax rt43's on today and they're a perfect fit.  I was worried if they'd be a little too beefy, but they look great.  No clearance or rubbing issues at all.  You'd think these were stock if you didn't know any better.  They fit the wheel well perfect.  Speedometer is going to be off a little, but whatever.
SHOdded said:
3.3% or thereabouts, but can be adjusted with tune/in IDS.
https://www.tacomaworld.com/tirecalc?tires=245-45r20-245-50r20
Tires look good!
Thanks - I'm happy with the look.  Pretty sure the % difference only makes a difference for the AWD system if i'm running different sizes front and back.  Shouldn't matter if all 4 are the same.  The snows i run are 3.7% smaller than the stock 245/45's and it doesn't affect anything.  Only thing that's affected is the speedometer.  No big deal for me.
panther427 said:
Glad you got them put on with no problem. Hope they improve your ride a little bit. Enjoy the new shoes
Thanks man.  Appreciate your help.  Everything you said was spot on.
