802SHO 2010 Build
No. I went to our local speed shop to see. They have some RPC Ones that seem to be bigger, but I need to do more research.
I like this one.  Sort of wish I bought this one instead.  Mine was like $120.  This one is just over $300 I believe
I think I want to retain the factory mounting position of my PP trans cooler, but just run a bigger cooler. I can buy a one of these for cheap just to see it if makes any difference at all. If I can get it into the 190's at 85 mph I will be happy.
Gotcha.  I wonder if it's doable to go with a larger cooler there and get some sort of fan on it.  Now there isn't any room in the front of the factory cooler for a fan but behind it...if there was some sort of fan behind it sucking more air through it that would be just as beneficial.
irondoor19 had added an auxiliary electric fan to his SHO (PI?), hope he will chime in here, or you can PM him.
Andrew I forgot to post the link lol....
https://www.jegs.com/i/RPC/707/R5054X/10002/-1
Something like this.  I know it will get direct air, but I am wondering it will make a difference. I will also allow me to run another 1.5 quarts of trans fluid....which always helps.  I am getting pretty good at pulling the front clip off the car, so this weekend I may just pick this trans cooler up, and install it. There is one at my local speed shop for 5 bucks cheaper than jegs and summit.  I have two quarts of trans fluid sitting on my shelf, so for $72 I am going to take the gamble....lol.
That cooler looks beefy enough to take on the job!  Glad to see you're taking cooling to the next level.  It can only make things better and last longer!
It’s all about the fffaaammmmmeeee!
I am just about done with mods this year.  Here is a list of everything replaced/upgraded/changed and maintenance thus far.
New GH turbos
New Oil and Coolant lines for turbos
New GH IC
New Alky Control pump
Dual Alky nozzle upgrade m5 m10 nozzles
EPP hotpipes
Derale 16 row 1000 series trans cooler
Changed from sp534 plugs to sp542 @.028
New Hood Struts
New front fender liners
New rear reinforcement bar
Stainless 4" quad tips powdercoated Satin Black
3rd Cat removed and added another 2.5" stainless Xpipe
New front wideband o2 sensors
New LR lateral arm
Billet Badges Carbon Black Ford Emblem painted Tux Blck
DIY front splitter 1/4" Abs plastic with FTR splitter rods
Upgraded 13+ SHO fender name plates dipped black
Vvid Gloss Black Vinyl on chrome window trim
1" Hubcentric spacers
Brake calipers painted black
Royal Purple 5w20 with K&N oil filter
Redline Lightweight Shockproof Gear oil in PTU + RDU
Trans drain and fill Mercon LV
Radiator flush
Very happy with all changes thus far.  Future plans are suspension upgrades, HPFP and Msd coils and brakes.  Also I'm sick of my wheel/tire combo and would like to change.  After that point engine and transmission upgrades would need to be done.
The Redline Lightweight Shockproof gear oil is the best I've ever felt my transmission operate.  The addition of the Derale Cooler to my existing 13+ PP cooler helps but not specifically as I had thought.  What the Derale Cooler does do is create a much slower temp rise in the trans fluid than before....it eventually still gets into the 190s and it topped out at 205 steady highway driving @75-80 mph with AC on.  Goes back into the 190's with the AC off.  But it starts dropping the trans temp in stop and go traffic and idling.  I'll need to revisit how I ran the lines for it, I believe I'm reducing flow the way i have it now, just wanted to get it in.
First time out to the track on 8/2/19 I was a little disappointed initially but now I think it wasn't all that bad.  I got only two runs in which really isn't enough to determine if I ran my best time for that day.  I left the car full weight with about 50 miles to empty.  The new IC, splitter and wheel spacers added to that weight about 50 pounds...but I certainly best my old full weight time of 12.06@115 with the 11.89@119.  My car didn't run its fastest 330ft or even 1/8 but it for sure had a lot more power in the top end than ever before.  Hard to say this is the best the car can do full weight.
So much fun watching you guys build your rides and tear apart misconceptions about the limits what this platform can do!  Just crazy how far we have come along in just the last couple of years.  Gen 4 is holding its own with Gen 5, not so long in the tooth after all :D
You can thank Shodded about the Redline Fluid, he got in my ear and my car's drive systems feel like they drive in velvet.  Nevermind the NVH and Tonka truck ride with the H&R springs and PP struts....lol.  Other then that, velvet.
I guess I need to look into Redline eh? Just been running motorcraft. I got the hook up on motorcraft fluids, but if it's that good good...
Jordan make the switch to Redline.  You won't regret it.  I was a little confused when ordering as it doesn't have a weight on it.  Shodded may have to correct me but I believe it has the same characteristics of the 75w140 and 75w90 so you just use it in both PTU and RDU.  Its designed for drag racing
You have a direct link? There is specific 75w140 and 75w90, but not sure if I am looking at the appropriate thing.
