SM105K said:802SHO said:Just in time for Revision 3 to start playing with Meth I also picked up another 5 gal VP M1 as I was all out. Perfect timing! Didn't need Meth for Revision 3 but we wanted to start playing so after I did a 3rd gear pull with just 93, I did a 3rd gear pull with Meth. Wow! As the old saying goes you don't know what you have until it's gone....when that meth sprayed even though I didn't need it...i felt it! Instant responsiveness....and check out my IAT2 temps! In just a single 3rd gear pull it dropped the initial IAT2 down 60 degrees putting me at 10 degrees below ambient! Simply amazing!
Decided to Google AWD Dyno near me...all of a sudden out of the blue...this other company Green MTN Gear-Heads pops up out of no where...literally never heard of them. I call, they DO have an AWD Mustang Dyno 1100SE in the ground...and they've been hiding in plain sight for the last 3 years 20 min from my house! I said ,"Huh? I've never seen you guys before on Google." "We're working on that", he said. Holy crap this is awesome! Made an appt June 13th at 3pm. Hoping Brad can do some remote tuning then or if need be I'll reschedule for when he can. At least now I have more time to get all my mods done as well!
And just think, you wanted to keep your junk stock IC......
FLEXXX said:how much boost? the -3 knock looks great!
StealBlueSHO said:I’m holding 17.8ish in third with the GH Turbos. Load hits 1.82ish and tapers to 1.76 at the end iirc...
802SHO said:StealBlueSHO said:I’m holding 17.8ish in third with the GH Turbos. Load hits 1.82ish and tapers to 1.76 at the end iirc...
Brad said 16,17 psi and we'll start to make the stock rods and pistons cry. He said I'll have to decide how far I want to go. My next revision is for 15 psi and meth. I may inch up to 16 then stay and dyno...not sure. Definitely want to play it safe as possible....within reason anyway ha!
shoNoff said:Go big or go home 20psi for both of youopcorn:
StealBlueSHO said:shoNoff said:Go big or go home 20psi for both of youopcorn:
I mean... I’m hitting 22 psi before the IC... does that count?
shoNoff said:StealBlueSHO said:shoNoff said:Go big or go home 20psi for both of youopcorn:
That’s sorta like when I told my wife it was 10 inches when we met. All lies
StealBlueSHO said:shoNoff said:StealBlueSHO said:shoNoff said:Go big or go home 20psi for both of youopcorn:
I suppose your were just “shoNoff”?
StealBlueSHO said:802SHO said:StealBlueSHO said:I’m holding 17.8ish in third with the GH Turbos. Load hits 1.82ish and tapers to 1.76 at the end iirc...
Yup, just depends on how he is tuning it. But seems right...
How many pounds of boost can stock turbos make? If i'm reading my log correctly i make around 18 lbs or so..
SHOdded said:Fingers crossed. These cars do chew up the widebands tho.
Also keep an eye on the battery. Little random electrical issues can often be traced back to the battery.
