I just installed mine last night, and I like them. The reason I picked this setup over crash is because this setup looks more low profile to me.
Big thanks to ddlopes for helping me out. The hardest part was trying to get the cable through the dash. Initially I used a coat hanger and I could not get it to come out on the driver side due to the wire being hard to bend. After talking to ddlopes, he said to use a wire and play with it until it appears, but I realized I needed to use a wire that was softer and easier to bend, and 5 min later, I had the obd cable through the dash(make a note, do not use a coat hanger wire). The wire came out above the gas pedal, and I didn't even need to remove the floor panel that covers the Mid consul. Taped one cable to the wire, and the Second cable about 5 nches lower for the first cable, and just pulled the wire. It's very tight when it Comes to space and I was Concerned that cables may get stuck if I placed all on the same spot, plus that area would not bend and flex as easy through the dash when being pulled up. Hope thIs helps Someone in thE future.
