I realized my after video I had windows down. So windows up here.
http://vid860.photobucket.com/albums/ab162/dxlnt1/Video/A21_zpsdazvyrek.mp4
All the 02 sensors are located in the front of the DP,you can probably see one if you look inside your engine at the bottom,right below the oil dipstick. Zsunwolf said:So am I correct in assuming you can do a 3rd cat/resonator delete without a CEL? Is there an O2 sensor past the 3rd cat?
Magnaflow makes a 2.25" x pipe do you think there would be a difference between the two?Dxlnt1 said:The MagnaFlow X pipe is pre-made at factory. Muffler shops just pull from shelf to install. You can have muffler shop build any size you want but would be too cost prohibitive for me.
It sounds really great without any drone or raspy sound effects,but better yet still retaining that sleeper sound,just to another level. ZDxlnt1 said:I realized my after video I had windows down. So windows up here.
sunwolf said:Magnaflow makes a 2.25" x pipe do you think there would be a difference between the two?Dxlnt1 said:The MagnaFlow X pipe is pre-made at factory. Muffler shops just pull from shelf to install. You can have muffler shop build any size you want but would be too cost prohibitive for me.
ZSHO said:It sounds really great without any drone or raspy sound effects,but better yet still retaining that sleeper sound,just to another level. ZDxlnt1 said:I realized my after video I had windows down. So windows up here.
Is there a lot of bad smell from fuel or anything else that u notice from non catted dps? Which ones do u have?ajpturbo said:I have catless down pipes and I feel no difference whatsoever tuned and stock....maybe my butt dyno needs calibrated and isn't as good as what others are using
ElvenSho said:Is there a lot of bad smell from fuel or anything else that u notice from non catted dps? Which ones do u have?ajpturbo said:I have catless down pipes and I feel no difference whatsoever tuned and stock....maybe my butt dyno needs calibrated and isn't as good as what others are using
Good to hear I plan to get the 3" dp from torrie once he gets them in stock in a month or so... i am just a bit disapointed that ur saying you couldnt notice a difference with dp's, u seem to know what ur doing with ur car.ajpturbo said:ElvenSho said:Is there a lot of bad smell from fuel or anything else that u notice from non catted dps? Which ones do u have?ajpturbo said:I have catless down pipes and I feel no difference whatsoever tuned and stock....maybe my butt dyno needs calibrated and isn't as good as what others are using
I have the stainless works downpipes. And no I don't notice any smells. I have the stock cat back so I have the stock 3rd cat and resonators and mufflers. So I guess the 3rd cat manages the odors and no rasp either for the record. but that doesn't surprise me considering the cat and resonator and mufflers.
The combo is ever so slightly louder than stock, sounds kinda deep at idle and startup but stock tone overall. Relatively quite I guess.
Nice! Yeah i am keeping an eye out for used dps while waiting aswell.Sabtaj1 said:no smell from mine either. Stainless works non catted with third cat and muffler with MRT axle back. I was gonna get the 3" pipes too but got a deal while waiting for them to be made so I didn't get them.
ElvenSho said:Good to hear I plan to get the 3" dp from torrie once he gets them in stock in a month or so... i am just a bit disapointed that ur saying you couldnt notice a difference with dp's, u seem to know what ur doing with ur car.ajpturbo said:ElvenSho said:Is there a lot of bad smell from fuel or anything else that u notice from non catted dps? Which ones do u have?ajpturbo said:I have catless down pipes and I feel no difference whatsoever tuned and stock....maybe my butt dyno needs calibrated and isn't as good as what others are using
SHOw-Me State said:Sabtaj1--
Liked the clip I heard of your exhaust. Eventually I may go the route you did, but probably with catted DPs due to inspection in Missouri. Which MRT axle back did you purchase? After a quick search, I didnt see anything specific for the SHO (or Flex in your case).
Thanks!
