Well I made some progress today. I took over 50 bolts/screws out to get to the intercooler. Also removed the actual bumper which involves drilling a few holes and 8 bolts.
The issue I see people having not wanting to do this is the shroud for the condenser/ intercooler needing to be removed. Shown below is the part that interferes.
My condenser has taken a beating as you can see where the bumper cover does and doesn’t cover. So what I did was “modify” the shroud .
I’ll be covering those spots back up with some semi-flexible clear acrylic I’ll drill and bolt down to the shroud.
There’s the difference between the two right now. I’m awaiting the replacement that’s coming in tomorrow and I work the next 4 days so I’ll be doing a little bit installation each night. It does sit right up in place so I don’t think I’ll have fitment issues.
Also tearing this down, these charge pipes are a joke. I think I’ll be buying the Eco Power Parts charge pipes down the road see how many bends and how thin the stock ones are.
Also discovered my driver rear wheel bearing needs replaced after doing a 4 corner brake job today. Timken replacement for $114 isn’t bad, considering local Auto parts stores want well over that any brand they offer.
