Articles on Lubrication
Has anyone heard of turbo maxx.  Www.Zddpmaxx.com this guy has alot of testing videos on YouTube and it seems to be pretty compelling.  He has developed over years in race engines.  One was a 400+ small block that lost water during a race and the main rod bearings were still perfect.  He also has a fuel additive c-4 that people are using and see less knock and cooler engine temps from adding only like 1ml per 3 gallons of gas, also better mpg as well.  I haven't bought any yet but going to try some soon.  I currently am trying hot shots secrets fr3 additive and that has quieted down the motor quite a bit on start up and I have seen a 1.5 increase in mpg.  For me it's not really a issue seeing how I have 205k+ on the old girl and has been tuned for 100k+ and have had a p0016 code for about 25k+ miles, I just reset and run it.  New motor in the garage so when it goes then the relief pitcher comes in.  Let me know if you check out his site and what you think.  No money in it for me just curious.
Motorkote for me in all my small engines.
In the SHO I have run it but not every oil change as I change it every 6 months or less.
https://youtu.be/88vwUwa3igQ
Conventional Oil preferred over Synthetic Oil?
:Boxing_gloves: :Boxing_gloves:
http://www.superchevy.com/how-to/additional-tech/1312-driven-racing-oil/
Purely cost-driven (for modern engines anyway), as it turns out in this excerpt:
However, conventional oils still have a place in performance applications. Engines built with rope-style seals should run conventional oils to reduce leakage. Likewise, engines that see high levels of fuel dilution should also use conventional oils. That's because the best thing for that type of engine is frequent oil changes, and the lower price of conventional oil makes it more affordable to change the oil more frequently.
Viscosity Improvers and Gear Lubes: More is not always better, and synthetic esters rule the roost.
https://www.klueber.com/blog/usa-canada/marine/shear-stability-is-key-to-proper-eal-gear-oil-selection/
AMSOIL sponsored testing, but note the method used for shear stability results.  I wish Redline LWSP had been included in this test.  IDK how much it would cost do this out of one's own pocket.
http://www.1st-in-synthetics.com/articles/amsoil_severe_gear_synthetic_gear_lubes_demonstrate_superior_shear_stability.htm
AMSOIL Severe Gear® Synthetic Extreme Pressure (EP) Gear Lube features an exclusive blend of high viscosity, shear stable synthetic base oils and an extra treatment of high-performance additives that provide a highly protective iron sulfide barrier coating on gear surfaces. Severe Gear Synthetic Gear Lube effectively protects equipment from thermal runaway through superior viscosity protection.
Insights on lubrication from a race engine builder
https://rehermorrison.com/tech-talk-98-oil-is-everything/
Perhaps even more important:
How does a racer know if the engine is momentarily running out of oil? Usually he doesn’t. That’s why I strongly recommend that every sportsman racer invest in a basic data logging system. A simple six-channel system can record everything a racer really needs to know: engine speed, driveshaft rpm, acceleration, battery voltage – and most important, oil pressure. These systems are affordable, and they are great insurance. The driver may not notice a drop in oil pressure on a gauge, or he may ignore an oil pressure warning light that flickers during deceleration. However, a data logger will capture even a momentary loss of oil pressure. That’s a wake-up call to improve the oil system or to change the shutdown procedure.
https://rehermorrison.com/tech-talk-99-more-about-oil-a-slippery-subject/
