I replaced this AA5Z19E616C what forscan calls HVAC damper position motorSHOdded said:Have you replaced the mode door actuator yet?
What fuse should I be looking for because non of these 15 slots look right except for 46 is climate control moduleZSHO said:There is sometimes a re-calibration procedure which need to be initialized Prior IIRC!
Both Blend door actuators on the (Passenger side) call for the same part numbers.. The one on the (Driver's side) calls for a different part number AFAIK. Z
NOTE: The purpose of the module actuator position calibration is to allow the HVAC module to reinitialize and calibrate the actuator stop points. To carry out calibration, carry out the following steps. Remove Smart Junction Box (SJB) fuse 15 for at least one minute. NOTE: When the ignition switch is switched to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds. Reinstall SJB (Smart Junction Box) fuse 15. Turn the ignition switch to the ON position and wait 30 seconds before verifying correct temperature blend door operation
Little bit different :sZSHO said:Slot 46 which has 10amp Fuse. (Climate control module). Z
Finally got the fuse pulled using wire strippersZSHO said:They look about the same IMO! That's right under the (Drivers side) dash. Fingers crossed for ya. Z
