bad turbo
mcrmb1
Well got the turbos pulled off the rear turbo is missing the nut on the turbo shaft what should i do next where should i look for the nut at????
The catalytic convert... it's probably on top of the mesh...
I would have thought it would be in the turbo or the piping.  Although at the speeds these things turn, it could be embedded in the metal housing.  Also check the intercooler.
Am I thinking of the wrong side of the turbine?
The nut that holds the compressor wheel on the shaft? That sounds like a problem..
mcrmb1 said:
its missing off of the compressor side could it make it pass the inter-cooler should i change it also
I don't think it could make it past.
The fins inside the intercooler are pretty tight.
Here's a video I posted awhile back draining the intercooler,
You can see the fins.
https://www.youtube.com/watch?v=LDvJwq7HXCc&sns=em
